m16 time1 無法正確 1sec 跑一次 timer1_ovf_isr
學習進度: 1sec 霹靂燈(五顆LED來回閃爍 1~5~1)
實作目標: m16/內建1Mhz OSC/ timer1方式 1sec 跑一次 timer1_ovf_isr 點燈
問題未解: 以 ICC AVR 內建的 Applicate Builder 生成的 time1 無法正確 1sec 跑一次 timer1_ovf_isr
以下為實作源碼,請學長們指正.謝謝.
#include <iom16v.h>
#include <macros.h>
#include "delaytime.c"
#include "led.h"
#include "led.c"
unsigned int timer1_count=0 ;
void LED_Init(void)
         DDRA|=0XE0;
         PORTA&=0X1F;
         DDRC|=0X03;
         PORTC&=0XFC;
void key_Init(void)
         DDRC|=0XE0;
         DDRC&=0XE3;
         PORTC&=0X1F;
//TIMER1 initialize - prescale:256
// WGM: 0) Normal, TOP=0xFFFF
// desired value: 1Sec
// actual value:  1.000Sec (0.0%)
void timer1_init(void)
TCCR1B = 0x00; //stop
TCNT1H = 0xF0; //setup
TCNT1L = 0xBE;
OCR1AH = 0x0F;
OCR1AL = 0x42;
OCR1BH = 0x0F;
OCR1BL = 0x42;
//OCR1CH = $OCR1CH$;
//OCR1CL = $OCR1CL$;
ICR1H  = 0x0F;
ICR1L  = 0x42;
TCCR1A = 0x00;
TCCR1B = 0x04; //start Timer
void Gpio_Init(void)
           LED_Init();
         key_Init();
        timer1_init();
#pragma interrupt_handler timer1_compa_isr:7
void timer1_compa_isr(void)
//compare occured TCNT1=OCR1A
#pragma interrupt_handler timer1_compb_isr:8
void timer1_compb_isr(void)
//compare occured TCNT1=OCR1B
#pragma interrupt_handler timer1_ovf_isr:9
void timer1_ovf_isr(void)                       // 燈號運作正常但時序不正確無法掌控...
//TIMER1 has overflowed
TCNT1H = 0xF0; //reload counter high value
TCNT1L = 0xBE; //reload counter low value
        timer1_count++;
        switch(timer1_count)
                case 1:
                          LED2_OFF;
                        LED1_ON;
                } break;
                case 2:
                         LED1_OFF;
                        LED2_ON;
                } break;
                case 3:
                          LED2_OFF;
                        LED3_ON;
                } break;
                case 4:
                          LED3_OFF;
                        LED4_ON;
                } break;
                case 5:
                          LED4_OFF;
                        LED5_ON;
                } break;
                case 6:
                          LED5_OFF;
                        LED4_ON;
                } break;
                case 7:
                          LED4_OFF;
                        LED3_ON;
                } break;
                case 8:
                          LED3_OFF;
                        LED2_ON;
                        timer1_count=0;
                } break;
void main(void)
CLI(); //disable all interrupts
         Gpio_Init();
         ALL_ON;
         delay_nms(500);
         ALL_OFF;
         delay_nms(500);
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x1C; //timer interrupt sources
SEI(); //re-enable interrupts
         while(1)
                          // led();
感謝各位學長們教導..@@
經過多方驗證後發現應該是MCU主頻錯誤導致頻率誤差.
這幾天一直誤認 PROGISP 中的 fuse 設定就是由片內讀取的設定 int 1Mhz.
經重新 fuse 設 int. 8Mhz+64ms 以 256 除頻 timer1 得出正確結果 1sec.
下列程式執行正確無誤...@@
TCNT1H = 0x85; //setup
TCNT1L = 0xEF;
OCR1AH = 0x7A;
OCR1AL = 0x11;
TCCR1A = 0x00;
TCCR1B = 0x0C; //start Timer
        timer1_count++;
void main(void)
         Gpio_Init();
         timer1_init();
         ALL_ON;
         delay_nms(200);
         ALL_OFF;
         delay_nms(200);
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x10;
         while(1)
                case 1:
                          LED2_OFF;
                        LED1_ON;
                } break;
                case 2:
                         LED1_OFF;
                        LED2_ON;
                } break;
                case 3:
                          LED2_OFF;
                        LED3_ON;
                } break;
                case 4:
                          LED3_OFF;
                        LED4_ON;
                } break;
                case 5:
                          LED4_OFF;
                        LED5_ON;
                } break;
                case 6:
                          LED5_OFF;
                        LED4_ON;
                } break;
                case 7:
                          LED4_OFF;
                        LED3_ON;
                } break;
                case 8:
                          LED3_OFF;
                        LED2_ON;
                        timer1_count=0;
                } break;
請問各位學長們:
設定 PORTC=0X03/ DDRC=0X03 後,量第2,3,4 依然是5V.這樣有正確嗎?
目前正學 KEYPAD 用到 PORTC 2~7, 可是怎樣設2,3,4 電壓都是 5V.
各位學長們有這情況嗎?經設定 PORTC=0X03/ DDRC=0X03 測 PC2,3,4,5 為高.測 6,7 可受控.
設 PORTD=0x00 / DDRD =0x00 測 PD7 為高,其他都正常.
這現象是 mcu 故障了?
謝謝學長教導:再問一個情況作為總結.
中斷 T/C1 OVL + comp A+B 三種一起使用可以嗎?
1)OVL 方式功能一直都正常
2) COMP A/B 偶不正常,如:開機進 COMP A 第一次就停了.
3)兩天前一直用OVL+COMPA+COMPB,今天忽然又無法使用了,是否是編譯器的問題?
代碼如下,
TCCR1B = 0x00;
TCNT1H = 0x85;
TCNT1L = 0xEE;
OCR1AH = 0x01;
OCR1AL = 0x38;
OCR1BH = 0x01;
OCR1BL = 0x38;
TCCR1A = 0x00;
void port_init(void)
PORTA = 0x00;
DDRA  = 0x00;
PORTB = 0x0F;
DDRB  = 0x00;
PORTC = 0x0F; //m103 output only
DDRC  = 0x00;
PORTD = 0x00;
DDRD  = 0x00;
keyVal = ((PINB&0x0F) ^0X0F);
timer1_count++;
TCNT1H = 0x85; //reload counter high value
TCNT1L = 0xEE; //reload counter low value
void main(void)
         port_init();
         timer1_init();
         ALL_ON;
         delay_nms(200);
         ALL_OFF;
         delay_nms(200);
MCUCR = 0x00;
GICR  = 0x00;
TIMSK = 0x1C;
         while(1)
                case 1:
                          LED2_OFF;
                        LED1_ON;
                } break;
                case 2:
                         LED1_OFF;
                        LED2_ON;
                } break;
                case 3:
                          LED2_OFF;
                        LED3_ON;
                } break;
                case 4:
                          LED3_OFF;
                        LED4_ON;
                } break;
                case 5:
                          LED4_OFF;
                        LED5_ON;
                } break;
                case 6:
                          LED5_OFF;
                        LED4_ON;
                } break;
                case 7:
                          LED4_OFF;
                        LED3_ON;
                } break;
                case 8:
                          LED3_OFF;
                        LED2_ON;
                        timer1_count=0;
                } break;
//                case 6:
        //                   ALL_OFF;
        //                   timer1_count=0;
        //        } break;
經查 <ATMEGA16单片机中文说明> 後發現 CTC 模式下比較觸發後會將 TCNT1 清零,
若此.則溢出中斷根本就不會發生了.可是網路上卻有不少範例是用 CTC 比較+溢出中斷,非常不解.
GMT+8, 2026-11-26 06:17, Processed in 1.063874 second(s), 8 queries, Gzip enabled.
