贡献stm32的16位AD7750驱动代码(SPI2)
求点评!求讨论!
  1. void AD7705_SPI_Init(void)                      // SPI 初始化
  2. {
  3. SPI_InitTypeDef SPI_InitStructure;
  4. GPIO_InitTypeDef GPIO_InitStructure;
  5. RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
  6. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  7. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  8. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  9. GPIO_Init(GPIOB, &GPIO_InitStructure);
  10. //SPI接口配置
  11. /* Configure SPI2 pins: SCK, MISO and MOSI ---------------------------------*/
  12. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  13. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  14. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                            //复用推挽输出
  15. GPIO_Init(GPIOB, &GPIO_InitStructure);
  16. SPI_Cmd(SPI2, DISABLE);
  17. /* SPI2 Config -------------------------------------------------------------*/
  18. SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  19. SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  20. SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                              //8个字节发送接受模式
  21. SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  22. SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  23. SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  24. SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;    //72M 64分频
  25. SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  26. SPI_InitStructure.SPI_CRCPolynomial = 7;
  27. SPI_Init(SPI2, &SPI_InitStructure);
  28. /* Enable SPI2 */
  29. SPI_Cmd(SPI2, ENABLE);
  30. }
  31. void AD7705_Init(void)                               //AD初始化
  32. {
  33. AD7705_SPI_Init();                   //初始化SPI
  34. Delayus(1);                              //延时1us
  35. AD7705_RESET();                    //写1 进行复位
  36. Delayus(1);
  37. AD7705_RW(0x20);                  //写命令 准备设置时钟寄存器
  38. Delayus(1);
  39. AD7705_RW(0x08);                   //设置时钟寄存器
  40. Delayus(1);
  41. AD7705_RW(0x10);                   //写命令 准备设置模式
  42. Delayus(1);
  43. AD7705_RW(0x44);                   //设置模式 自校准,增益1,单极,无缓冲
  44. SysTickDelay(1);                        //延时1ms
  45. }
  46. //读写ad7750芯片函数
  47. unsigned short AD7705_RW(unsigned short data)
  48. {
  49. //读取数据放入软FIFO
  50. u16 rdata;
  51. //AD_CS(0);
  52. /* Wait for SPI2 Tx buffer empty */
  53. while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
  54. /* Send SPI2 data */
  55. SPI_I2S_SendData(SPI2,data);
  56. /* Wait for SPI2 data reception */
  57. while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
  58. /* Read SPI2 received data */
  59. rdata=SPI_I2S_ReceiveData(SPI2);
  60. //AD_CS(1);
  61. return rdata;
  62. }
  63. //写1复位
  64. int AD7705_RESET(void)
  65. {
  66. int i=0;
  67. for(i=0;i<5;i++)
  68. {
  69. SPI_I2S_SendData(SPI2,0xff);
  70. SysTickDelay(1);
  71. }
  72. }
  73. //采集函数
  74. u32 GetAD7705(void)
  75. {
  76. u16 rdata=0,temp=0;
  77. AD7705_Init();
  78. temp=AD7705_RW(0x00);
  79. temp&=0xff;
  80. rdata=AD7705_RW(0x00);
  81. rdata&=0xff;
  82. temp=(temp<<8);
  83. rdata|=temp;
  84. SysTickDelay(1);
  85. return rdata;
  86. }
复制代码
GMT+8, 2026-5-31 13:16, Processed in 1.043070 second(s), 5 queries, Gzip enabled.
